who did your install? i'm in the bay area too and we're in the process of picking an installer. thanks
oops sorry I didn't see this earlier.
I work for a large company and my employer arranged employee discounts with Sunpower and REC Solar, so I got quotes from them. I also got a quote from a company based in Berkeley called Sungevity--they're a solar startup that a coworker referred. Ultimately I went with REC Solar.
The Sunpower quote (actually a quote from a local Sunpower premier dealer called Cobalt Systems) ended up being very high relative to the other two. The Sunpower panels are somewhat more efficient and look sexier (all black monocrystalline silicon instead of the cheaper and multicolor polycrystalline silicon panels the others use), but because my panels aren't really visible from the front of my house and because i had enough prime roof space for the size system I wanted i really couldn't justify the (~30%) greater cost i was quoted. I found out later that my boss had a much larger (7kW) system installed by Cobalt and found they were the lowest quote he received. So.. YMMV w.r.t. price but FWIW my boss said he was very happy with their work.
REC is a large company and have done many installs, including my brother's down in San Jose. They have an electrician present at every install, and they were willing to be flexible (installed a RS-485 card in my inverter and ran some conduit so I could run a serial cable for monitoring purposes--the monitoring option they offered seemed kind of pricey, ~$1500 vs ~$750 or so for me to do the same thing). With the employee discount, REC Solar came in the lowest, but not by much.
Sungevity was willing to meet (actually slightly beat) the REC price, they were very responsive throughout the whole process, and they were willing to squeeze me into an earlier installation window at my request (time to install was an important criterion for me). They were an outstanding company during the pre-sale process and I very nearly went with them.
In the end the REC guys committed to the same timeframe as Sungevity, and they were both ~same price, so I went with the larger company, but I gave serious thought to going with Sungevity. As it turns out the REC guys ended up having to push my date back a couple of weeks (right after I signed my contract :huh
, so it's hard to say whether I made the best choice but the actual install went smoothly and I haven't had any problems.
If you're looking for an add'l company to give you a quote and you haven't spoken to Sungevity yet, I'd suggest giving them a call and seeing what they can do for you.
One caveat: I had all three companies provide me initial quotes before doing an on-site evaluation. It turns out after doing the onsite eval, REC had to revise (downward) their estimate of the generating capacity of the system (some shade due to the neighbor's tree that wasn't evident looking at the satellite photos i guess). If you want a more accurate estimate and don't mind some add'l delay for scheduling, that's probably your best bet. In my case, the difference in the CA solar rebate (which is based upon how much electricity your system will generate under real world conditions) ended up being pretty small so the system will only end up costing me a few hundred dollars more than the estimate.
HTH
-js
