BraveSirRobbin
Moderator
Solar Design Suggestions Needed
I have to specify, order, and implement a solar powered system for a field data acquisition project for work. The system will run 24/7 in a remote Nevada area.
Here are some of the system requirements:
1 amp at 24 hours = 24 amp*hr continuous load
Battery will be 75 to 100 amp*hr rated (deep cycle).
Solar panel will be rated at 120 Watts. This will be capable of supplying (120Watt/12Volt) 10 amps of current during the daytime.
Assume worse case of only five hours of daylight this solar panel will yield 5*10 = 50 amp*hours per day (approximately double the 24 amp*hr draw per day by the equipment).
A 10 amp rated pulse width modulation charge controller will be connected between the solar panel and the battery. This will provide diode isolation during the night time (when no current is supplied from the solar panel, thus not providing a discharge path for the battery) as well as voltage regulation as the solar panel can provide a voltage as high as 22 volts during peak sunshine (of course the peak voltage is very dependent on the load as well).
I have two questions.
1) Is a factor of two sufficient between the solar charge capability and the load as this will account for (multiple) cloudy days?
2) Are the parts specified below sufficient for the overall design (any red flags based on user experience or some unknown that I did not take into account)?
I appreciate any input as I’m not familiar with solar systems and thought possibly some of our members might have experience in this field.
Solar Panel:
Mitsubishi 120 Watt Solar Panel PV-MF120EC4
http://www.altersystems.com/catalog/mitsub...ec4-p-1667.html
Here is where I could really use some recommendations. I elected to go to a single panel rather than parallel two 60 Watt units, mainly for ease of installation and cost. Does anyone have a better suggestion (brand/size/type/etc…)?
Charge Controller:
MorningStarr Sunsaver 10 Amp Controller SS-10L-12
http://www.altersystems.com/catalog/sunsav...-lvd-p-347.html
This controller is rated for use up to 60 degrees C (140 F) which is the main reason I like it. It also has the diode (reverse current) protection scheme necessary for the night time.
Battery:
I was initially thinking about a 75 amp-hr deep cycle (blue top) Optima battery, but am wide open to suggestions based on a member’s experience.
Are the Odyssey batteries worth their high price? I’m not looking for cold cranking amp capabilities obviously as I will only be drawing one amp continuous, but would like to have three days or so of reserve power. Plus these batteries do have to operate in extreme heat during the summer months.
Thanks again for any comments and suggestions.
Regards,
BSR
- 12 volt DC operated equipment
- 1 amp constant draw all day and night
- Temperature extremes from freezing to 115 deg F (in enclosed field box) during the year.
Solar Panel:
Charge Controller:
Battery:
Regards,
BSR
