Sam, I've encountered a problem with the custom Logic Block you posted.
I reset my Premise server and started with a clean slate. I imported the XDO and Premise threw an Alert; it could not digest a LinkObject described in the XDO.
LoadStringValue() failed for property 'LinkObject' on object
'sys://Schema/Modules/Default/Classes/ChangeText/'
-- contents: '{89A408E8-0E7B-4879-8B38-4318C079AF19}'
I chose to Ignore the Alert and the Default Module was populated with a new class called ChangeText. The class contains the following properties:
Input
Reset
Result
Text
and a nameless class icon ... that would be the unresolved LinkObject that Alert carped about.
When you look at the Changetext class, what do you see as the first entry in the Content Workspace? The first entry for a custom Logic Block should be the FunctionBlock class and is created for you when you use the Class Wizard.
BTW:
Custom Logic Blocks can reside in any Module and not just the Default module. If that's not true for you then something is amiss somewhere.
Try importing the attached XDO and let me know if it works for you. It should create an IncrementBlock residing in a MyLogicBlocks folder. The IncrementBlock is an example from Premise's Help file.
NOTE:
I deleted the unamed class and pasted in the FunctionBlock class (copied from IncrementBlock) into Changetext. I exported and imported Changetext without throwing an Alert and it happily sits in the MyLogicBlocks module.
