Keeping the phase couplers should be O.K. but they are really needed anymore.
Now on the repeater, you only have one, correct? I THINK you can have more than one, but fully check the instructions. A UPB "packet" can only be repeated once, and the repeater keeps track of what is and isn't repeated.
Make sure you enable UPStart to work with a repeater. UPStart has some great debugging tools for use with a repeater. Try to run these and see if that can identify a problem. Focus around the area where the switch signal is the worst.
The only other thing that I can think of is a bad UPB Computer Interface, or a weak one, but its pretty rare. The PCS one is the best if you are connecting it to a computer. I'd use the HAI one for connecting to the Omni panel.
