sda
Mount it to the left if there's room, or mount it on the adjoining wall.Mount it above the MCB box?
Per the NEC, you need working space around your electrical panel for service. The electrical panel needs to be in a space approx 30" wide x 36" deep (from the wall) x 78" high. No permanently installed "stuff" can intrude into the space and it shouldn't be used for storage either. The NEC code is 110.26.
Scenario: If you mount your enclosure in the working space and at a later date have some electrical work done that gets inspected, you'll probably have to move your enclosure.
