I have recently moved into a newly constructed house that I homerunned everything. I ran approx. 37,000 linear feet of Cat5, RG6QS, Security Wire, Etc. I terminated all my Cat5 into four 48 port patch panels. Now I am in the process of completing my ELK M1G. I am using a Channel Master 42 inch can. Mounted the M1G almost to the top, leaving room for wiring runs at the top. Mounted the battery below and to the side about 5 inches from the Master control. I have 15 FOUR WIRE System Sensor 4WTA-B. Two M1SXP Lighting Thermostat interface serial port expanders, Two Battery Shelfs, Two Batteries, TRG1640 additional Transformer, FOUR M1XIN 16 Zone Expanders, PD9HC Power Distribution Module. Two Round Acoustic Glassbreak Sensors, Five Glass break Sensors, 20 Comet PIR , 2 360 degree infrared detectors, 6 door sensors, water valve shutoff and 10 water sensors. I realized i didnt order the data hub and will do that tomorrow.
My first question, is there a preferred layout in the 42 inch can for the equipment?
I am a little confused on the 4 wire smokes and how to wire them in. I am wanting, if possible, when one alarm to sound that they all do. But also, is there a way to wire it that will tell which smoke detector originated the alarm? If so, is there a particular way to wire it or is that in the rules? I ran the Belden Red smoke wire (4) and the colors are Red, Black, Blue, Brown. Any particular order of colors to the input on the panel? How exactly do you use the EOL relays for the 4 wire smokes and with 15 smokes, how do you use the +SAUX and NEG with that many? Do you use the first 15 left side terminals for the smokes? I have researched the ELK site, read the manual many times and am still lost.
Your patience is appreciated and I know i'll have lots of other questions for the next few days.
