Work2Play said:I saw a pretty interesting tool at Lowes the other day - it was a handle you use to grab onto the drill bit at about mid-point to help angle/guide it... anyone tried one of those? I'm not able to find it online - don't know what search term to use.
+1 on the screw-tip drill bit - with the 2nd option I've had them bounce and just go out through the drywall into the room instead of through the stud - the first one grabs the wood and pulls itself through pretty effortlessly.
For long Flex bits (aka D'Versabit), made by Klein, Greenlee and others, this auger tip
is MUCH better than this
When that is all you have (got a LOT of use out of mine) somehow you can make it work!:lol:![]()
For success with that second, crapulent bit, I figured out that it must be exactly perpendicular to the top or bottom plate - not simple when flexing the bit.
I use that guide handle to keep the rotating shaft off the endges of the switch-height cut out.
I've literally spent an hour or more trying to make that crappy bit work, on some attempts. The last time I tried using it, I got frustrated, and bought the new one - took 8 seconds to chew through.
I hope you travel by car as I'm pretty sure you'll never get a flex bit through airport security. I have a better idea, you come to Denver and volunteer to do a bunch of work for me and get some "on the job" training. I'll learn you good...Anthony, I have suffered with that shitty bit on a number of occasions. The screw tip is INVALUABLE. I'll toss it after 100 holes, and buy another, when it stops performing.
The screw tip saves time, and prevents frustration.
Next time I visit Denver, I will bring the crapulent bit with me, and you can have it.![]()
Tattoos are optional but, you won`t fit in without at least a few...on your hands.I'll be sure to check it; will fit into my ski bag.
Is morning or evening better for you, to pick me up at the airport?
Will you make me get some ink done if I show up without my tool bag? :rofl:
