Honeywell 5800RP & ELK
So I've got an ELK M1 with the M1XRF2H wireless receiver and several 5800 series wireless devices.
I am using a 5800RP wireless repeater for wireless zones in my garage. When I installed the 5800RP, I setup a zone for supervision in the M1 (for low batt, RF jam and other errors) as per instructions. Now I'm getting a "transmitter missing" error for that zone, so my question is, does the 5800RP "check in" like the other Tx's do or do I need to keep that zone as "no supervision" in wireless setup?
Would appreciate info from anyone who has used a 5800RP.
Matt Barrett
Hotwired Electric LLC
The 5800RP does periodically transmit and the panel does look for the "check in" of the unit. It should be supervised.
Sounds like a location or possible distance issue if the panel's receiver can't hit the 5800RP's supervisiory transmission.
Thank you sir! When I went to set supervision back on I saw I left it on loop 0 by mistake, good now!
Matt
