I installed it on my htc evo 4g
It is very slow from tap to execution. Like several seconds often times.
It correctly loaded all of the VAR values
It states unbound for all temps, this is incorrect, I have one temp connected.
It correctly control the outputs, but sometimes with a delay
It crashes frequently
It lists 8 analog inputs (unit only has 3) with all at a value of 313. This is incorrect. I have aip1 in use and the value is currently 137
It has a green dot next to ttl inputs. I don't know what that means. I am currently not using any of them
It lists a humidity value. I don't have anything connected to humidity.
EDIT: Additional stuff
In the overview section, it has not picked up correctly my firmware version, date, time, or urom values.
Also, if the output state changes, the android app does not pick up the change, even if I hit refresh.
