nemesis
I am testing out my glass break sensors (Bosch 1108I) with my OmniPro II panel. I have the glass breaks set as Perimeter Zones. If I place the sensor into test mode and arm the panel I can set the alarm off using Bosch's tester (Bosch 1110I). If the sensor is not in test mode, the tester does not trigger the alarm, however the glass break sensor itself does light up. These sensors have the ability (via a jumper) to be place into a latching mode. I currently do not have them latching. Could the sensor be triggering and letting go so fast that the panel does not register it? In which case should I use the latching feature? Any ideas on what is going on common procedures would be greatly appreciated?
