jurdim
Hello:
I have a question regarding 1 x 8 Channel I/O (4 Relay Version)
After installing the I/O card that i ordered april first it appears in my 1-wire web directory but the only way i can switch a relay is by entering a number in the PIO.BYTE field using the 1-Wire Web Directory, the numbers are
1= r1 on
2= r2 on
3= r1+r2 on
4= r3 on
5= r1+r3 on
6= r2+r3 on
7= r1+r2+r3 on
8= r4 on
9= r1+r4 on
10= r2+r4 on
11= r1+r2+r4 on
12= r3+r4 on
13= r1+r3+r4 on
14= r2+r3+r4 on
15= r1+r2+r3+r4 on
I can't switch them on in PIO.ALL by changing 0 to 1 or by marking the appropriate box in PIO.0 thrue PIO.7
When i try to adress it using winscp and PuTTy where i use the following command in the commandline: echo 1 > /tmp/1wire/29.EA6D04000000/PIO.0 it should switch on relay 1 but is does not.
I installed the I/O card without any changes to its factory settings i dont have the external 12V or the external 5V connected.
Can you tell me whats wrong or what i am doing wrong.
Grtz Jurgen
1= r1 on
2= r2 on
3= r1+r2 on
4= r3 on
5= r1+r3 on
6= r2+r3 on
7= r1+r2+r3 on
8= r4 on
9= r1+r4 on
10= r2+r4 on
11= r1+r2+r4 on
12= r3+r4 on
13= r1+r3+r4 on
14= r2+r3+r4 on
15= r1+r2+r3+r4 on
Grtz Jurgen
