Tiny Tasmota Garage Door Opener - Temperature Sensor - 2 contact sensors
This is a redo / rebuilt of a Tasmota Sonoff Basic generation 1 that has been working now for 3+ years.
This works fine with the Tasmota web interface, Homeseer 3-4 and Home Assistant.
Note with the Sonoff Basic R1 cut the 120VAC traces of the board with a small saw.
You need some soldering skills for this project.
This is being done to take the MyQ GDO off of the Internet. I also have the OmniPro 2 panel connected to the garage door opener and sensors.
Sandbox house is using the MyQ GDO (2 years now)
Hardware: (all items purchased on Amazon)
Wemos mini D1
Wemos mini D1 relay hat
DS18x20 temperature sensor. Here soldered the drop down resistor between data pin and vcc and extended 3 wires about 8" or so from Wemos D1 Mini. I heat shrink wrapped the end of the sensor with resistor. Doing a second one and will take some granular pictures of it.
2 contact magnetic reed sensors
Modified garage door button for my garage door opener.
LiftMaster 883LMW Wall-Mounted Wired Push Garage Door Opener and Doorbell Button with Light Button *
* Must be LiftMaster branded garage door opener button. This is the modification to convert digital button to analog.
6 port electrical outlet with USB ports. This is the one I purchased and using.
Drawing of wiring for relay hat when soldered in to place. D1 is GPIO 5.
Wiring drawing - pics - made two of them.
1 - solder the Relay hat over the Wemo Mini D1 - pin label to pin label.
2 - diagram of pins used.
3 - DS1820B20 - rewire to short cable - noticed when wired directly to Wemos D1 Mini sensor was too warm.
4 - Tasmota configuration with one reed sensor connected. Note "toggle 2" is reed switch 1. When garage door opens it goes to "on"
Tasmota commands in console specific to GDO.
pulsetime1 1
This makes the devices relay activates for a second, The garage door will think it’s you pushing a button.
Switchretain 1
This will make it so that Home Assistant gets the last state from the door sensor after a reboot.
Powerretain 1
This will stop the relay from randomly triggering when the Sonoff disconnects and reconnects to the MQTT broker.
Configuration using Home Assistant Cover.
This is what I see using devices created by the mini GDO with temperature sensor. First entity is the button to open the garage door.
Second entity is the reed sensor.
IE: switch.tasmota is the button and switch.tasmota2 is the reed switch.
Put this in my configuration.yaml file.
Code:
cover:
  - platform: template
    covers:
      garage_doortp:
        device_class: garage
        friendly_name: "Garage Door TP"
        value_template: "{{ is_state('switch.tasmota2', 'on') }}"
        open_cover:
          service: switch.turn_on
          entity_id: switch.tasmota
        close_cover:
        stop_cover:
Code:
icon_template: >-
          {% if is_state('switch.tasmota2', 'on') %}
            mdi:garage-open
          {% else %}
            mdi:garage
          {% endif %}
After restart now have a cover entity which I called cover for time bean. It has an up, stop and down button.
The issue I had was that it automagically created a cover for the myQ garage door opener in house two.
I have Amcrest PT cameras in each garage looking at the garage doors in each house. This helps me validate function of the new GDO.
Enclosure for new combo GDO.
