It appears that the Home Assistant MyQ integration is no longer working. I have patched a couple of Python scripts to get it working over the last month and it did work for a few days.
I have always had issues with the use of MyQ and cloud connectivity. Initially it was helping a neighbor set it up and poor lack of customer service.
I have been testing / using three garage door remote control methodologies.
1 - Leviton OmniPro 2 panel wired connectivity to GDO button and two wired contact sensors on garage door. Never an issue with it.
2 - Tasmota originally using modded Sonoff basic then upgraded to Tasmota Wemos D1. This is a combo push button, temperature sensor with two wired contact sensors as documented here:
Tiny Tasmota Garage Door Opener - Temperature Sensor - 2 contact sensors
This DIY GDO has worked for years and has no dependencies on the cloud. Always worked fine.
3 - MyQ - hub installation with remote garage door sensors * Always problematic and bad CS.
4 - Included GDO remotes and automobile GDO integration. (Homelink). Never an issue.
* I can still use it with my phone but no longer use it with Home Assistant.
This is what worked and now doesn't work with Home Assistant MyQ integration. From reading posts (many shut down now) it appears to be an authentication issue and relating to the Home Assistant Core which always included MyQ integration.
Myq integration stuck on initialization
OmniPro2, Included remotes and Tasmota integrations are best. Tamota integration uses WiFi and a bit of soldering and very cost effective (under $10).
