Thanks guys, I appreciate the feedback. For Cat wire, I will only be using Cat6, I just wasn't sure on the stranded/solid. unless Cat5e would be better in some applications. Wouldn't I need to home run my thermostat wire back to my rack? Or is the thermostat wire only from the HVAC unit to the thermostat, then I can use cat6 from the thermostat to the HAI(Hasn't been purchased, still debating on which system, I want to go with)?
Will it matter if these wires are stranded or straight cat6?
I have my walls open right now as I'm putting an addition onto my house so I just want to make sure I have all of the correct wires in place, and run conduit to major areas in case I need a new wire.
