oldchachie
id like to switch a load using an ELK 912 relay with 12v dc signal and a 120vac switched load. My problem is ive always understood that one needs to separate 120v from low voltage. So some questions:
1. Using a 912, could i just put this in a regular single gang box, run the 120 and low voltage wirea in and hook them up, from an nec perspective?
2 is there a special type of box for this?
3. Is there something else id have to do to use a confiuration like this?
4. Does anyone know of a relay that can be mounted in a single or doublw gang box that has a built in divider for the high and low voltage?
Im really looking for awnsers on how to do this from an nec perspective.
