I am planning to use Somfy Sonesse 30 motor for windows drappers. The spec says I need to use 16/2 conductor wire. I am having hard time finding this wire. Can I use any other wire?
Just don't go "smaller" than 16 gauge wiring. This means (in wire gauge terms) you want a wire gauge that is less than 16 (wire cross sectional area increases with reduced wire gauge numbers).
If this is for surface wiring, 16/2 would be heavy duty lamp cord or heavy duty extension cord. Otherwise for in-wall, use 14/2 romex. The home supply stores should carry all of these.
