beelzerob
We're laying some water pipe down in the back yard. One pipe goes to a winter-safe outdoor house bib. Basically, the handle on the top opens a valve that's on the bottom of the stick, which is buried down 3 ft. And when you close the valve, it causes all of the water in the vertical shaft to drain back down out the bottom into a little sump...those no water is left above ground, which is why it's freeze-safe.
However...one of our other desires is for a little sink on our deck. What I'm trying to figure is how to do the same thing with that, but with a normal faucet. My options seem to be:
1) Just remember every year before the first serious freeze to close the supply valve and manually drain the line....somehow.
2) Use the same spigot yard-faucet contraption instead of a normal sink faucet.
3) Somehow use some controlled water valves and a thermometer to automatically drain the line when the temperature gets close to freezing.
The first scenario is the easiest, but also just as likely to majorly fail...should I find myself in vacation when a freeze unexpectedly hits the area. Then I'd have a burst water pipe while away.
The second was nixed by the wife, as she doesn't want a big metal valve and hosebib thing sticking up out of our deck, and I agree. Besides, we don't know exactly where the sink is going to go yet, so I can't put it in permanently.
The last one is too baffling for me at this point. I'm trying to think of what combination of valves I could use. The only scenario I can think of is if I had a valve on the supply side, and then a valve at the bottom of the vertical section of pipe to the faucet, then I could turn off the supply valve, and then open the "drain" valve, and that would allow the water in the vertical section of pipe to drain out. The main thing I don't like about this is that it means a valve would have to be buried 3-ft down. That's certainly a failure point. I don't think I could even leave a valve access cover on it, as then it wouldn't be insulated for the winter and I'd once again have a freeze potential.
Anyone have any suggestions on a better way to make an outdoor sink faucet freeze-proof?
