DELInstallations said:
			I am not reading a question in regards to your post, so I'm unsure if there is actually one.
In the case of IDF and the construction of telco plants, there's generally a cheap carbon supressor installed at the Dmarc for the premises. It's designed to help prevent backfeeding from the subscriber's equipment to the telco, really not the opposite way, and honestly, it's effectiveness can be argued significantly.
No questions were asked.  A well proven solution was defined.
  In the 1950s, new technology (transistors) meant telcos reviewed existing protection.  So that transistors would be unharmed even by direct lightning strikes.  With minor corrections, 'carbons' (properly earthed) protected transistors from direct lightning strikes and other lesser transients.  A typical CO might suffer about 100 surges with each thunderstorm.  That $multi-million computer was protected from lightning and lesser transients (such as backfeeding from subscriber equipment).
 Today, telcos use better, semiconductor based protectors. (Transorbs are insufficient; telcos use better technology.)
  A protector does not do protection. Carbon, gas discharge, or semiconductor is irrelevant.  In every case (as was true in the 1950s), protection was about where hundreds of thousands of joules harmlessly dissipate. Protection is defined by how energy connects to single point earth ground.
  A protector, adjacent to an appliance, does not claim to protect from destructive transients.  Protector, adjacent to what absorbs energy, protects even from lightning.  As carbons did before the 1950s.  Effective protectors connect energy to earth. And do not fail.  Effective protection means hundreds of thousands of joules (ie lightning) dissipate harmlessly in earth.
  This well proven and less expensive solution is provided by responsible manufacturers including Eaton (Cutler-Hammer), Siemens, Intermatic, Ditek, Polyphaser, ABB, Square D, Leviton, and General Electric - to name but a few. Similar solution is found in any facility that must suffer direct lightning strikes without damage even to a protector.
  In every case, a well proven protector connects hundreds of thousands of joules (ie a direct lightning strike) harmlessly to earth.  A protector is only as effective as its earth ground.
   A  telco 'installed for free' protector and an AC 'whole house' protector must both connect low impedance (ie 'less than 10 feet') to the same earth ground.  Otherwise, a voltage potential can exist between those two items when transients start happening. Causing alarm damage.  Effective protectors make a short connection to earth.  Protection, even in 1950 CO, was always about how a protector connected the transient to earth.
