I would like to add some files to the \Windows directory on my Elk TS-07 touch screen, but it looks like they get wiped out after the unit cycles power. Is there a way of adding files to that directory, without losing them every time you reboot? Thanks!
You are probably adding files to the RAM directory storage space. There is not much room in the Flash directory space. There is a compact flash socket on the PCB. The new ELKRMS will use a compact flash memory for its storage area in the TS07.
The files I have have to be in the \Windows directory, if I put them on flash, is there some way of making it look like they are in the Windows directory (i.e., using hardlinks or something like that)?
