wallyllama
I just recieved two solar radiation sensor boards. I haven't connected them yet, but I am curious about calibration. I assume the 1-wire net will return a number that is proportional to the voltage on the sensor, but I could use some advice on calibrating that to some standard.
Initially a relative reading will suffice, but my future plans would work better if I can relate the readings to a known value.
Some of the things I would like to do are measure the amount of sunlight available for solar panels, find out if there is enough light (or shade) to grow certain plants in my yard, etc. I don't need laboratory grade precision, but I would like it to be as accurate as I can.
