Aeon Labs Z-Stick
Does the software download (labeled beta and staing only for those with shlage locks) from HS' website give you an error? The only "issue" that I had was that it didnt recognize the serial number of my device but wrote anyways...
Oh.. Just realized that I used Controlthinks firmware upgrade software but pointed it to the WD file. There was a key combo in the software the allowed you to load a bin instead of using the included file.
Let me know if you require further help.
Good Info - will give it a try.
I currently have a Vera 2 and would like to interface with it via my televisions. My thought was to setup a usb Z-wave controller as a secondary to my Vera. I would then plug the usb stick into my HTPC/WHS and interface with it via Media Center. I've hit a roadblock though because I can't seem to load up the Z-Stick with the z-wave network data from my vera. Sounds like it's this "missing installer files" issue.
I suppose my only option here is to create a second z-wave network with everything on the Z-Stick? Or to go another route entirely and try to write something to communicate between Media Center and Vera.
