wkearney99
I've got a mishmash of automation gear, Lutron, SmartThings, Wink, Vera, Homeseer, Philips, Fibaro, Aeon, Wemo, Leviton, Samsung, Iris, Blink, well.. you name it and I've probably got one lurking around here.
I'm interested in consolidating a bit, but I'm unclear on how z-wave and master and slave controllers function... and whether any of the hubs tolerate interacting with each other.
I'm still interested in fiddling around with different gear, but I've had pretty decent luck relying on a Homeseer 3 Pro setup on a PC for managing "stuff that needs to stay working". It's been worth the money I spent for it. But it's UI is clunky and it's event system is challenging to use (at best).
Meanwhile I discovered my SmartThings hub has been hammering away issuing millions of bogus DNS queries for Lord knows how long, which I tracked down to a long-removed 1st gen Hue hub. While solving this riddle I noticed the ST system was no longer properly monitoring various leak sensors I've got around the house. The were inexplicably "offline". Power cycling them by removing/replacing their batteries brought them back (all of which still show better than 44% battery life). I'm debating just taking them out of the ST setup and moving them elsewhere.
A number of the gizmos use z-wave. Before I move them en masse to my HS3 setup (which is just NOT having it with a Aeon S2 z-wave stick I had lying around) I want to get a better handle on how z-wave systems share devices.
Presumably some hub setups are more flexible than others, right? Which ones tolerate, or better yet refuse to, work with other hubs? If I have to choose one to be the master, which one should it be?
