jkmonroe said:still sitting here on my couch, listening to the Echo.
with a Sonos HT setup 15 feet away, and another Sonos Play:1 about 10 feet away. the Echo is just too easy.
Agreed... Echo is easy, but if you use Jishi's node-sonos-http-api from GitHub, and the echo-sonos app also on GitHub, you can use Alexa to control your Sonos system. I've slightly extended the echo-sonos app to give it bit more functionality, and it works pretty well. You are a bit limited in that you can't have Alexa start just any old Sonos stream, but you *can* have it start Favorites, so as long as you have a Favorite defined for the stream you want, it works. With my current setup I'm able to start music, group and ungroup rooms, pause and restart music, change volume, play a specific genre of music, play a specific artist (this gets a little tricky and doesn't work with every artist), set or unset Shuffle & Crossfade. Anyway, while it does require a bit of specificity in how you instruct Alexa to issue Sonos commands, it's way cool and works pretty darned well. I love being able to just blurt out "Alexa, tell Sonos to pause the Kitchen" and presto, the music stops. I intend to get a few Dots to spread my Sonos (and my lighting system) control to a few more rooms. Being able to have Alexa turn on and off lights through my OmniPro II, and control Sonos throughout the house is definitely making me like voice control! Apple should have been here with Siri a couple of years ago, but they flubbed it and let Amazon steal the show.
