Anybody using PowerLinc USB 1132U with SERVER?
WayneW
Is anybody using the SmartHome PowerLinc USB 1132U x-10 interface with HomeSeer and Windows 2000/2003 SERVER? SmartHome claims it isn't supported on server versions. I am guessing the limitation is due to the SmartHome included software, rather than a hardware limitation. I will probably get one from Martin if somebody can tell me it works on Win Servers.
electron
Administrator
Staff member
I use the USB Powerlinc with Homeseer on Windows 2000 Server, without any problems, I assume you are talking about the model without memory? All I did was install the Homeseer plugin and that's it, I believe the device is HID compliant, so you shouldn't need any drivers.
AutomatedOutlet
Wayne, I use one with XP PRO. Works fine. I don't see why it wouldn't work with your server SW. If it doesn't work, you can return it!
Martin
