****Cross-posted from AVSForum.com****
Heyas!
I recently installed two Wayne Dalton Series 9600 insulated doors, and two WD Zwave enabled iDrive openers. Overall I am really happy with the doors and openers, so much better than the contractor grade doors I had. The openers are super quiet and clean up the garage ceiling.
Anyway, I'm trying to get the lighting set up. The ZWave openers do not come with the lighting accessory, although you can buy it separately. I'd rather tie into the garage lighting anyway, as I installed four in-ceiling flourescent fixtures that out perform some crappy overhead bulb.
Per the instructions I purchased a ZWave in-wall switch (HA18C). I also purchased the ThinkEssentials software and ThinkStick rather than a remote to learn the scenes.
The TE software quickly recognized the switch, but would not recognize the iDrive opener itself. It "sees" the opener, but it is an unknown device.
I've been doing a few months of research on HA, and will slowly start building up my solution. Fortunately, my home came with a security system with hard-wired door and window sensors, so that should be a big help. I've been messing with Windows Home Server and CQC as well.
As far as ThinkEssentials and the iDrive opener, I posted on the ControlThink forums, but haven't had a response yet.
So, here is my question (finally):
Is there any software out there that recognizes the Zwave opener?
Thanks!
Trick414
Heyas!
Thanks!
Trick414
