McKinneySmart
Good point on the fuse vs PTC issue. Agreed, the PD9 is not the best design in all applications. Sometimes a real fuse is required especially if the current draw is greater than 400ma.
The PD9 is great in the situation where you have numerous device of low current and using the same voltage. The PD9 can operate between 6 and 30 volts AC or DC. Motion detectors and glass break detectors are excellent candidates for the PD9 because they all use 12vdc and have a typical current draw of less than 50ma. Plus the PD9 offers a clean way of terminating the power leads of these external devices. Instead of 'wire-wrapping' them together. In the greater percentage of the time, my voltage requirement for external devices has been 12vdc. I have run across other voltages a few times. And yes this is problem with all those power supplies, aka bricks.
Now an audio amp that needs 2A is out-of-the-range of the PD9 and probably needs its own power supply.
And now I am seeing more devices that have a 5vdc brick. So a separate 5 volt distribution system would be nice. But I really do not have a need for that, right now that is.
OnQ/Legrand/Grayfox had a great solution to power distribution in their structured wiring enclosure modules. Most of their modules operated at 12vdc. Some at 15v. They had a power distribution module(s) with short low-voltage jumpers that would go to the individual modules.
As far as 110vac distribution, I also include a AC strip like the Channel Vision C-0702 or similar in my installation. Plus have the electrician install an AC outlet in the bottom of the Leviton can. Most of the time I will also install a separate 14 enclosure just for the AC power cords/bricks/plugs.
The best advice at this point is put in an enclosure that is twice the size of what you think you may need, or twice the number of enclosures.
