Does it concern anyone that the US government has removed Hikvision cameras from it's embassies:
https://ipvm.com/reports/hik-removed-embassy
Mike.
Mike.
mikefamig said:Also if I block outgoing traffic will I still be able to view the camera from outside the firewall?
OK so then I should be able to just delete the gateway address from the cameras and access them with BI?batwater said:If you use something like Blue Iris or some other camera NVR then no it's not an issue, you set your firewall up to port forward the Blue Iris server and you are done.
mikefamig said:OK so then I should be able to just delete the gateway address from the cameras and access them with BI?
The camera needs the gateway address and dns servers to get out and address anything outside the LAN and I read that you can simply delete the gateway address in the camera to defeat outgoing traffic.batwater said:I'm not sure I understand your statement about deleting the gateway address from the camera but yes you would access the cameras via Blue Iris instead of going directly to each camera.
mikefamig said:The camera needs the gateway address and dns servers to get out and address anything outside the LAN and I read that you can simply delete the gateway address in the camera to defeat outgoing traffic.
Mike.
