I got the Roomba Discovery SE for Xmas 04 and have played with it some. As a vacuum it does a decent job but the main advantage is that it can vacuum daily and you don't have to be around. What I mean by that is that it takes much longer to actually vacuum a room than a person with a vacuum would but you are using a machine's time and not yours. The fact that I can run it daily or nightly more than makes up for any power it may lack over a 'regular' vacuum.
One of the original Roomba complaints was that the dust bin was too small. This one is still small when compared to a regular vacuum but has been plenty large enough in my use so far. The first time through each room the dust bin got completely full but each pass after that has filled the dust bin less and less. Eventually it would probably get to the point of not needing to empty it daily but I think it is a good idea because I'm sure it would cause problems for it to overflow.
Click here to view the article
