There's a long thread (345 posts) from 2013 on LED bulb options, with quite a bit of discussion about LED inrush current and the affect it can have on switches and dimmers. Just wondering what reality has shown over the last nine years, and whether or not I should be concerned about LED usage at a new home. To date, my only experience with LED bulbs are incandescent replacements, with only one or two on any given switch.
The home will have most (maybe all) LED lights. Some will be LED bulbs in fixtures. Others (quite a few of them) will be can-less recessed lights that each have their own driver. I doubt any will be more than 12W (60W incandescent equivalent?), and most will probably be less. Although initially I won't be using any smart dimmers/switches, I will gradually install some as we get used to the home and figure out where smart dimmers/switches will do the most good.
Since the fixtures containing LED bulbs will have at most three 40W equivalent bulbs, I'm mostly concerned about the recessed LED lights that may have as many as eight 12W recessed LEDs on a single dimmer/switch. Seems like most LED dimmers and switches, smart or not, have a maximum of 150W of LED lights (or 600W of incandescent) per switch. Are the manufacturers taking LED inrush current into consideration at 150W maximum? If so, it seems like at a maximum of eight 12W LEDs on a switch gives me a lot of breathing room.
Or, am I missing something that further limits how much "LED wattage" I can put on a switch?
Along the same topic... I'm being very conservative on what is on each individual circuit, and every non-appliance circuit will be 20A. Assume I have eight 12W LEDs on a single switch, but there are additional outlets/lights on the same circuit. Do I need to be concerned about turning on the eight LEDs when there is already maybe 12A of consumption on the circuit causing the breaker to trip due to the LED inrush current? Or is the inrush current time so small that the breaker can handle it?
Ira
Ira
