I'm using several 0-10V dimmable LED floodlights at our new home (still under construction). In addition to the 120Vac wires, these lights have "0-10Vdc control wires" between the dimmer switch and the light to control the brightness. I plan on using the appropriate dimmer switches for them.
Anyone know if connecting the two control wires (or capping them separately) at the switch location and using a regular toggle switch to control 120Vac to the light will work, i.e., the switch will turn the light on/off, but it will always be at full brightness when on? Just wondering if this is an acceptable temporary solution if one of the dimmers go out.
Ira
Ira
