CT Droid
CT Bot
Â
View the full article
ano, thank you for writing this it looks like it is going to open up a realm of things once this all goes mainstream into production.
Will the Home Automation Profile, Telecom Profile be able to talk to the Smart energy profile and vise versa?
Todd,
Currently there are a few issues with HA profile talking directly to the SE profile. These issues involve security since HA and SE devices uses a different type of security. SE devices come preloaded with a specific key, where HA devices do not. So if you already have a SE network in your house setup by your utility company, buying a generic HA device from "Bob's devices", will not be able to fully communicate with the SE network. There are a few features in the SE profile that is considered unsecured and some devices may broadcast these attributes to anyone who wants to listen (ie current price of kWh). So you may be able to buy a magnet from Home Depot in the future, that will just display the price but does not actually join the network.
To solve the HA and SE merger, you really have to have an application level bridge on a device designed to specifically do that (will join both networks). I could be wrong but I have yet to see a device available that can do that. There may be a way in the future to accomplish this, but I do not see an immediate solution as of right now.
Now this is not to be confused with a device that can run both profiles at once. As long as all devices run the same type security it should not be a problem. So you can effectively run an HA type device with SE security. This way you can control the thermostat's settings (HA profile stuff), from an in home display if they are part of the same SE network.
Ryan
Not to answer for Allen, but I think it falls outside the 5 and is known as RF4CE as was mentioned in the article.The article states that all remotes will shortly switch over to ZigBee but when I look at the 5 standard profiles I don't see something that looks like Device Remote or some such thing. Does the remote control functionality fall under one of the 5?
Why ZigBee over Z-Wave? I'm a do it yourselfer and have been watching Z-Wave, and dabbling in a few devices here, just waiting to jump in. But, I don'nt want to jump in with Z-Wave if ZigBee is going to the be standard/rage. So, my question is what is the present status between Z-Wave and ZigBee and what does the future hold? I want to ride the horse, but don't know which one to get on. Help?
I got the part about the IR replacement but was confused by the fact that it it appears to only be point to point like and old IR remote. If the remotes don't fall within one of the big 5, will they be able to be part of the system and be controlled/monitored by higher level applications? I suppose I was guessing that there would be something that looked like a standard TV/DVD Player/Tuner (AV Profile) that could eaisily be accessed via a ZigBee network.
Exciting stuff, I hope it all pans out!
