While we lose a small amount of efficiency due to the storage tank, the benefits of the system far outweigh the negatives. The system works flawlessly. We get hot water almost instantly at any point in the house. Once hot water is called for, the tankless heater(s) will fire to replenish what is being drawn from the storage tank. When there is no demand, the tankless heaters never run - even though the recycling pump is running.
All very accurate and valid observations! Without being defensive about it, let me go through a little of the thought process behind our design decisions. Your ultimate design will reflect your personal desires and concerns, the size and design of your house, and your location! Without going down too much of a rabbit trail, I did a ton of homework on all our systems decisions (ex-engineering background kicking in)!
The thread has done a pretty good job of showing that everything in residential home design is a trade-off! We definitely had some specific criteria in mind with respect to the design of our hot water system, and absolute energy efficiency wasn't our #1 criteria. Depending on what's most important to you, you could end up with a very different system design! We live in a part of the country (North Carolina) where domestic hot water isn't commonly used for heating (we use high efficiency heat pumps since we require as much cooling in the summer as heat in the winter), so a lot of our criteria related specifically to personal hot water use needs.
- Not running out of hot water was probably the #1 criteria! With hot water loads that vary wildly (depending on how many kids are home and how many friends come along to spend the week-end), I can absolutely say that we don't ever run out. This has a huge WAF - especially when she wants to draw a bath in the jacuzzi tub and is able to fill it in 5-7 minutes (given the high flow rate fill valve) with comfortably hot water! A trade-off between absolute efficiency and luxury? No argument here but hot water is one of those things that you take for granted until it's not there!
- Given the size of the house, to omit a recirculating loop would mean extremely long "wait" times to get hot water in most areas. I previously lived in an older house where we had to run faucets at the "far end" of the house 3-5 minutes to get hot water. Running that much water down the drain is pretty painful, and more than a little inconvenient! Any way you design a recirculating loop it isn't as energy efficient as not loop! In our case, the recirc pump doesn't run all that much, the recirc piping runs through conditioned spaces (and is insulated for what it's worth), and the small back-up tank draws pretty modestly. Retrofitting an existing home with a recirculating loop is typically pretty tough, but we were looking at new construction and the additional return run for the loop was a very small cost item!
- We live out in a pretty rural area and can (and do!) lose power - sometimes for extended periods (we are prone to ice storms). I wanted a system that would operate with a very low power load on our generator, and propane fired tankless heaters work extremely well. We lose the recirc pump electric "back up" tank, but having
any hot water when the power craters is almost priceless!
Conventional tank heaters were never a consideration for me! There are too many negatives in my mind given our specific needs - capacity limitations, energy requirements on the generator, physical size, passive losses, etc. Will our system "pay for itself" versus other design options - tough to tell! Does it do exactly what we wanted it to do in our situation - again this is a big "yes"!
Point of use heaters also wouldn't meet our needs, because there are a lot of "demand points" to satisfy including tubs and showers! If we were in an existing home this could be a valid option, especially if there are only a couple of sinks that needed a "boost".
Sorry to run on so long on this, but it's a great example of how complex design trade-off's can be in home design - and how there are a lot of good answers to every problem! We had the ability to work with a blank canvas on our project and spent a lot of time evaluating each piece of the puzzle. Building a new house vs retrofitting an old one is a very different process, and clearly a lot of our decisions would have been different if we were doing a remodel! The fact that we plan to be in the house for a very long time also came in to play in a lot of areas. I clearly wouldn't have gone as "overboard" in a lot of the areas we did if I was only going to be in the house for a few years.
Enjoy the decision making process and rely on your team of sub-contractors for their input! A lot of things that look good on paper don't necessarily translate so well when it's time to come up out of the ground with the thing!
- Rick
