I looked around a bit and could not find the answer to this one. Is there a better place to find Noobie answers like this?
I have a ELK with an elk-m1xin (http://www.elkproducts.com/pdf/M1XIN_Input_Expander.pdf)
I am hooking up a NEXT K9-85 Motion PIR (http://www.smarthome.com/73904.html) (install doc is here:http://www.visonic.com/VisonicHomePage.nsf/sysAllDocuments/7EAAAE0591C04C2CC2256BFD0021130E/$FILE/Next_K985_English_Installation_Instructions.pdf)
There are 8 contacts on the PIR
Tamp 1
Tamp 2
N.C. 1
N.C. 2
EOL
12V+
12V-
TST
I assume that I connect it like this
Tamp 1 - OPEN
Tamp 2 - OPEN
N.C. 1 - Z1 (M1XIN)
N.C. 2 - NEG (next to Z1 M1XIN)
EOL - connect to N.C. 2
12V+ - +12 (M1XIN)
12V- - NEG (next to +12 on M1XIN)
TST - OPEN
Questions:
1. It seems to work, but I needed to setup the ElkRP as Type = Normally Closed. I would have expected it to work with the EOL.
2. Also what about the "Tamp" contacts. I assume this is "loop tamper protection". What is this?
3. How many PIRs can I connect to the +12v of the M1XIN?
Unrelated question. I plan on running a single wire up to my attic, and then putting my ELK-M1DBH, M1XIN, and M1XRF up there. This way I don't have to run as many wires up into the attic, and I assume the XRF will get better reception up there. True?
Tamp 1
Tamp 2
N.C. 1
N.C. 2
EOL
12V+
12V-
TST
Tamp 1 - OPEN
Tamp 2 - OPEN
N.C. 1 - Z1 (M1XIN)
12V+ - +12 (M1XIN)
TST - OPEN
Questions:
