Update July 31, 2021
Did the same as above for a 2001 E46 which has mostly sat around for the last 20 years. This is the same engine as the E83 and originally the E83 was built on an E46 chassis.
This time went with Brembo rotors and Akebono brake pads. Note this was a brake kit sold as a package.
While doing the right rear brakes / rotor noticed the coil spring was broken on the bottom almost identically to the E83.
Very easy to remove the rotors this time around as there was no rust keeping them in place.
Ordered same springs as I did for the E83. Lesjofors brand made in Sweden.
The installation looks easier than it was on the E83.
1 - jack up automobile at point a bit to the front of the rear wheel (jack point)
2 - remove wheel
3 - jack up strut / shock and remove bottom bolt of strut
4 - lower jack on strut which will lower wheel closer to the ground
5 - using flat tire scissors jack separate top of wheel a bit from chassis
6 - reach in and remove old spring and rubber from top and bottom
7 - install new spring with upper and lower rubber sections
Looks way easier than using a spring compressor. Last time could not fit it easily between the spring and the wall section around the spring.
2 - remove wheel
