Refrigerators, by code, require a dedicated circuit, I think.
I have 2 in my garage - one is not on a dedicated circuit, but it only holds 'beverages'.
If you can, add some exterior outlets as well - car vacuum, hedgeclippers.
I had a spigot added to the outside of my house last fall. The only spigot near my garage was inside the garage, surrounded by [peeling, damaged] drywall. I had a plumber add a valve along the supply line to that spigot, so I could shut it off during the winter. The spigot is located on an exterior wall, between 2 garage bays, and subject to freezing.
Add a spigot at the back of your house?
Have you considered irrigation/sprinklers, and where the controller might be located? Wire runs to the controller?
All good points.
Hookup up a car vacuum should work from the outlets in the back and the front. However, the garage has a whole house vacuum inlet so I plan to be vacuuming from there.
On the outside, it comes with 3 power outlets.. I will have one next to the garage, one on the porch and one in the back. These are expensive to add with the builer. I think I can add ones to the side without too much work after I move in.
The house has a hose bib on the front and the back..
I am not doing irrigation with the builder, but hope to do that once we figure out all our landscaping. I will put the controller in the mechanical room with HA stuff.
I guess I haven't really thought beyond that - is there anything that needs to be run from the controller that I can't run from the unfinished basement?
