I think I have a great automation idea for your laundry room. Technically you are supposed to turn off the water valves leading to your washer when you aren't using the washer or in the house. I know sometimes we start a load and leave the house so this wouldn't work for us or a variation would. But anyway set your HA system to shut down two valves leading from the water supply to the washer in the even that your are away or on vacation?
The alternative and amazingly over the top plan would be to use current sensors to trigger the valves open when you turn the washer on. That would take some experimenting. Our new LG washer warns if the water is off so I don't know if the current draw would be great enough to cause a noticable difference than just sitting idle. You could modify your washer to open the valves. Too bad washers don't come with serial ports
Neil
Neil
