I've got Engine 1.15 running OK, but it doesn't seem that the Dashboard, nor the Cassini software is seeing any local ports. The firewall has an exception to allow the port thru, but nothing is happening. Tried re-installing pretty much everything, but no joy....When I attempted to install the Cassini Web Server, I kept getting an Error Code 2869.
I turned off my UAC in Vista and the error goes away.
When I go to http://localhost:9009 the dashboard loads with my circuit names but I never get any data.
Any ideas?
Is the ECM Engine running and collecting data? You need to start this, get it collecting data, and set it to log to a database (just a checkbox). It took me awhile to get this working. After pulling my hair out for about 15 mins, I power cycled the 1240, and then it started working. I had my 1240 flake out one other time also when I was messing with settings and it required a power cycle that time also before it would start sending valid data again.
I found Brultech has posted an updated version of the ECM Engine. Version 1.11.
It fixed the problem with not being able to save the cost per kilo watt and added a database write status.
Yes, I verified my ECM engine is logging to the database.
I will try the power cycle.
I tried the power cycle but I still don't have any data in the charts.![]()
Any ideas?
Any ideas?
Any ideas?
Look to see if there is a serial number in the section marked Serial/Device Binding.
My serial number kept missing from this section every time I restarted the ECM engine.
I have to add my serial number every time and then select 'Bind'.
Hope this helps.
I am now trying to get every thing working on Windows 7 64-bit.
Anyone do this yet?
Any ideas?
Hope this helps.
Anyone do this yet?
I just installed the engine and the dashboard on a Windows 7 64 bit machine. The best I can tell, the Engine is not actually writing to the database (even though the database write status says otherwise). I would really like to get this working so I can actually use the ECM 1240 I purchased a few months back ...
I got the dashboard working by installing the 64 bit version of the System.Data.SQLite.dll. So, it appears to be working, but nothing is getting written to the database.
Regards,
Ultrajones
Yup, that sounds right. 2x7=14 and they have 14 loads identified. Unit 1 Ch1 is the main feed. They don't identify exactly which loads Unit 1 Ch2 and Unit 2 Ch 1 & Ch 2 are monitoring, but it could be almost any of them.how many units do you think run that thing? it looks like two I guess as you get 7 channels total per unit. Am I missing something or does that sound right
Has anyone taking a look at the sqlite DB that acts as the backend for this?
The software looks nice but I want to be able to set up some warnings in CQC if certain conditions are met. And I would like to do some other things to massage the data.
I use sqlite DB for the database storage for the tenEcmServer products. I think that is where Brultech got the idea.
http://www.tenholder.net/tenWare2/tenEcmSe...cmDbLogger.aspx
tenholde
One feature that I would find very valuable, is to allow me to multiply a channel by a number (in particular 2). My HVAC system uses 2- 240V circuits, I have one coil on leg of the 1st circuit and one on the other leg of the 2nd circuit. The come in as channel 2, but as a 120V load, so the kw usage is off by a factor of 2.
