Can M1 send a warning
richard
Can the M1G work in this way?
I want to be able to blast a warning sound / shot from the outside speakers "a voice announcement" as a panic
to a triggered keypress, but not put panel in a call for help startup.
Not sure if M1 is suited as it stands or additional hardware is needed to control?
If the process would raise the volume, speak a message outside for 10 seconds, then return volume back to original levels on a 2 key sequences, that would be a great "bump in the night" alert. I could add outside drive lights and floods as an addition.
Any ideas on a warning blast but not an alarm & police response that the M1G can handle?
The voice announcement on level 7 is really loud.
Then the panic request for help is always still available.
Thanks.
(really making progress on the M1)
Hi,
The standard outside speaker on the M1 can't deliver voice messages. There is a rule action you can use "chirp the siren X times" - You might be able to use this.
If you wanted voice outside then you could either have some auxiliary speakers that you connect to the Out-1 output via a relay when you want to make an outside announcement.
You could also use an Elk-110 voice module connected to a relay trigger.
Paul
