element2050
I'm new to this and working with a preexisting system with zero suuport from the prior owner. I've connected the Pro to my router, on the Pro board the red light is on by the rj45 port. The device doesn't show in my router's table in connected devices, but the light on the router indicates something is plugged in. I have been able to ping the IP address in my computer and it did return 2ms. I've tried to access the IP via web browser with no luck. I have went to the touchscreen console and pulled the keys, ip, port,. What am I missing?
I have also tried to use Superlink lite version for android, I've typed in the Keys, IP, port, and user code; nothing happens. Is there a way to verify the setup without PC access or buying snaplink.
Do all Pro's support networking out the box? Is there something that needs to be turned on? I have the older board that needs chip updates, there are two chips on my board 2.13 and 2.0. I do not have PC access yet and am kinda glad since I'm pretty sure it wouldn't work if superlink isn't.
