Just a quick update for everyone...
CastleHUB Kickstarter
Only 5 days left on the CastleHUB Kickstarter! If you haven't reserved yours yet, now is the time!
https://www.kickstarter.com/projects/506540480/castlehub-universal-smart-home-intelligence-by-cas
New Protocol Support
We've promoted TCP Connected devices from the "will support" to the "is supported" category! For those of you trying CastleOS on your home PC while awaiting your CastleHUB, feel free to try out the TCP smart bulbs with CastleOS! (As a personal note, we do find the quality of light the TCP bulbs produce to be on par with other high end bulbs.)
App Updates
We've also released a major update to the CastleOS app's graphic design. This isn't a render - it's in production now and you can download it today. We've replaced static image buttons with interactive and touch sensitive switches.
The new switches more clearly indicate the current state of the device (on/off), are animated, load faster, and look a lot cooler and more modern, if you ask us! They also work across all your mobile devices, no matter the brand or OS!
Amazon Echo
Many of you have asked about Amazon Echo support, so we wanted to pass along an update on that.
Use it Today
Currently, Amazon has released support for Belkin WeMo and Philips Hue devices. You can verbally give the Echo commands that will adjust the state and brightness of the various WeMo and Hue devices. We expect Amazon will soon roll out more support for UPnP smart devices as well. While these commands are not issued to CastleOS directly, CastleOS does monitor all the changes to the status of each device. In other words, CastleOS knows if you've adjusted a device via the Echo, and can act on that information, for instance by using it as an event trigger for a stored event. The benefit of using both together is that CastleOS and the CastleHUB fills the gap between what the Echo provides, and what's need for a full automation system. The Echo is great about translating a speech command to the device, but it does not have an intelligence built into it. It cannot follow up the command with new actions, kick off scenes or events elsewhere in the home, etc. Pairing it with CastleOS accomplishes this. In practice, this means you can use the Echo fully with CastleOS today, however only with WeMo and Hue devices.
The Future
When Amazon releases the full API for the Echo, we'll be launching support for interfacing with the entire CastleOS system, similar to how we currently do with the Kinect. Until then, feel free to use your Echo with WeMo, Hue, and more!
Thanks everyone!!
