Well I would first check your house/unit code against the defaults of other manufacturers, and your logs to see if this is cause by the powerline or the pullchains/wall switch.
Then if all that pans out I would remove the pull chains and blockoff the wall switch. See if it still happens, I'm thinking it will not. I have several of these installed and have had no issues but they are cheapo X10 so you could even have a defective module or who knows what else.
What are you using for x10 control?
