wonder why would you want to move from HAI to a different HA software if it has worked for you so far.
Never moved/migrated anything here. Always playing with hardware and software because its a hobby.
I have migrated though from X-10 to Insteon to UPB for my in wall light switches. (I have in place X10, some Insteon, Z-Wave and ZIgbee)
I had a combination security, TTS and X10 panel in the 1980's to 1990's. I went to Homeseer in 1998. Bought a new home in the early 2000's and at that time purchased an OmniPro II. Built another home and put second OPII panel there.
Purchased more HS2 licenses and another OPII panel in the 2000's. Today one OPII panel serial ports are all being utilized. I have also added a "few" Omnitouch 5.7's and Omnitouch 5.7e's. (added the Omnitouch CCTV / Touchscreen hub). Also have two Russound zoned amps connected to the panel (12 zones). I still today also utilize the older AB8SS which is connected to more speakers. (we are at 20 zones here of audio).
Production Homeseer is running on two Wintel Server boxes with close to 30 pieces of hardware (20 on one and 10 on another).
Homeseer 3 on Linux is running with only a few scripts and a few plugins; mostly one at a time to play with.
The migration from Insteon to UPB started slowly as I wanted Insteon to work. It was a natural progression from X10 to Insteon.
I had no issues controlling the Insteon switches using the OPII panel connected with JV Digital XTB amplifier. Today the OPII panel is connected to the dual phased TW-523 device that Jeff sells.
One day a few years ago had an electrical debacle which fried most of my Insteon switches. Over the years I had been updating failed Insteon switches. I had no issues doing that.
I do recall making a scene at an Insteon display once at one EHExpo mostly griping about the junk that they were selling.
The home was already about 1/3 UPB and 2/3 Insteon when the electrical debacle happened.
I removed the rest of the Insteon and upgraded to all UPB. I did another upgrade more recently removing many UPB switches and replacing them with dual load multiple paddle UPB switches. They are doing fine today.
My HS2 HAI serial plugin is working fine these days. The beta HS3 HAI plugin while not finished yet works fine.
I am "playing" with other automation software and hardware. I always have done this because I enjoy automation as a hobby.
I did get involved a bit relating to creating a plugin for the OPII panel in Homeseer 3.
Today the HS3 Ubuntu 64 bit test box is using variables from the HS2 Wintel Server relating to the new HAI Homeseer 3 plugin.
I am seeing faster response times with the old OPII Homeseer 2 serial plugin. (also in side windows watch the HAI logger program, Java HAI stuff, OpenHAB stuff out of curiosity mostly these days).
![HAI-Serial-IP.jpg HAI-Serial-IP.jpg](https://cocoontech.com/data/attachments/4/4651-638d6beab4b8ba03e0cbc2559dec883e.jpg)
