Finally getting around to installing an alarm on a prewired house I moved into a few years ago. Long story short, I'm down to a single wiring/sensor problem and there is no continuity (confirmed with DMM and probe/continuity tester). The prewire install was lazy (pigtails connected by twisting and taping, mounting tape directly on dirty surfaces, etc.). Now, I've got a single home run of about 25 ft between a window and the panel, but am unsure of the least invasive way to correct the problem. I'm tempted to tie a new run of wire to one end and yank on the other end to try to pop any staples in-between and pull the whole thing through, but I worry that it will just snap somewhere in the middle and I'll be the worse off for it. Any recommendations on how to fix this? Thanks!
