My "el cheapo" tester helped me when I installed POE cameras to the edges of the property. I initially wired them using the old LED style tester and most of the terminations had been done incorrectly. The newer tested tested the wire for correct pairing standards. The little termination device has a beeper on it when their is end to end connectivity. Not sure how accurate the length of the cable testing. None of my runs exceeded 300 feet. It was a lot of practice using a RJ-45 crimper with short pieces of catxx cable and while time consuming if you make a mistake easy to do it another time. I printed a large color of cable chart to help me do this. Just unravel the end of the cable and flatten the 8 cables out in order and while pressing them flat cut the end flat across and slide it in to the RJ-45 connector which is clear and you can see if the wires are in the right grooves. Takes practice so make yourself some patch cables to test with. For wall sockets I still had issues with the colors. Many times punched down the connections tested them wrong and would re punch them live connected to the tester until I got it right. Never had to do this for a living but DIY learned for myself.
Many years ago a friend built a new home ~ 300 feet from his old home on a farm. Initially he used the internet ISP connection in the old house so I had him run underground cable to the new house from the old house and used this tester. Today he is still using this cable. He owns an apartment building in town 13 miles away and I wanted to originally to put in a wireless bridge from town to his house (had a clear view at the time).
Practice buying a bag of RJ45 ends and some short catxx cables. It will come easier to practice first.
My issues where relating to lining up the cable color order and keeping them flat next to each other and sliding them in order inside of the RJ-45 connector. Print your guide picture with terminal clip up or down and do them all the same. Hold the flattened cable with your thumb and first finger on one hand and the RJ45 end in the other hand. Once you slide the cables in to the RJ45 end, look inside of the connector to make sure the ends are all even then crimp the end on.
Get a good compression style crimping tool. These are also cheap now on Amazon.
