I will be using a 42" panel from Leviton. It will house my OmniPro ii, HiFi2, Cisco 24Port POE switch. I am sure I will add more later down the road but that should get me started.
My concern is heat. My switches here at work produce a lot of heat that gets routed out of the rack.
I was wondering if I could use two 24V fans to circulate air. I am new to automation but couldn't I even place an temperature sensor in the cabinet and wire the fans to one of the outputs on the board. Then create a rule to turn the fans on if a certain temp is reached.
I can run a vent and pull the air from the room and was hoping I could just vent it into the wall.
How have you guys handled this in the past?
Mike
Mike
