jcrack_corn
i'm not sure how it can get easier or mor accurate than a rotozip and circle attachment, and pack of fresh bits (about 100 dollar total investment)....
Make sure you get the circle tool very tightly locked down at the adjustment nut (they give a really big knob for this), and make sure you always have a fresh bit (change about every 8-10 circles cut in drywall) --->note, those bits are still good, but you want really fresh ones for circles because it cuts like butter so you dont risk opening up the tool if you are having to force the rotozip through the material (ending up with a spiral instead of circle)...when cutting plywood for outside speakers, change the bit every 2 or 3 circles....
Follow those steps and dont be cheap with bits and you can install lots of speakers in a short amount of time (i did 10, with wiring in 2-3 hours, with attic access)....most of the 2-3 hours was spent marking the drywall in the attic for proper spacing (here's a tip, use a 1/64th or 1/32nd drill bit and drill through drywall from above, then check the location (make sure it ended up in the part of the room you wanted, perspective is skewed from the attic sometimes)..if you need to adjust, the hole wont be visible from the floor and can be fixed with a dab of caulk and dab of paint on fingertip....)
