felixrosbergen
What Outdoor siren should I use? Can 150RT be directly power by the M1? (150RT states 1.25A power draw, M1 states output power limited to 1A) or is a separate driver needed?
If mounting the strobe SL1 to the outdoor siren (e.g. 150RT) does it need separate wiring? I plan to run 18/4 Firewire to the siren and use 2 conductor to power the siren and 2 to monitor the tamper. Do I need to run additional wiring or does the SL1 ‘piggyback’ with the siren? If it doesn’t piggyback and needs separate wiring where does it connect to? If i want to be able to operate the strobe independent from the siren and still monitor the tamper in the 150RT i assume i will need to run 2 18/4 firewires correct?
What wiring to run from M1DBH to M1XSP? 22/4 or Cat5? DBH needs RJ45 plug but does 22 gauge fit in RJ45 plug (Cat5 is typically 24 gauge). ?
