beelzerob
So I've determined that I have a York Affinity series 3S heat pump, and I've found a user's manual and also some technical data...but nothing clear that can answer these issues from the RCS TR-15 thermostat installation manual:
1) Jumper JP2 is facotry installed for common transformer heating/cooling systems. For separate RC and RH transformer systems, cut jumper JP2.
2) Most heat pump systems are designed to work normally in the heating mode and require a change over output for cooling. Set dipswitch SW1-3 to the CO/CL position (OFF-default) for this type system. Check your HVAC system requirements for correct settings. If your system requires change over with heating, set SW1-3 to the CO/HT position (ON).
Of course, the installer isn't in this weekend, so it's either get help from the community figuring out which way to set those things, or wait until Monday.
