While I haven't found any official press releases yet, it looks like RCS just announced the availability of a new Wi-Fi thermostat.
Features:
HVAC Systems Compatibility:
Features:
- New All-in-One Design
- Wi-Fi Enabled Thermostat � iPhone Compatible
- Compatible with Wi-Fi Networks � Easy Set Up
- Thermostat Control Program Software Included
- Standard or Heat Pump HVAC Systems
- 128x64 Backlit Graphical Display
- 6 Buttons with On Screen Labels
- Remote Control of Thermostat Functions
- Optional Remote Sensors
- Wall mount or mounts on single-gang junction box
The TW43 is a Wi-Fi enabled wireless digital thermostat, designed to control HVAC systems. The TW43 contains a robust thermostat interface and is designed for use with networked systems where remote monitoring and/or remote control are desired..
- Central HVAC systems or separate heating/cooling systems; can use separate RH/RC transformers (split)
- Standard gas/electric HVAC Systems: 2-stage heating, 2-stage cooling
- Heat Pump HVAC Systems: 3-stage heating, 2-stage cooling
- Fan system: Selectable for gas or electric heat systems
- Heat Pump Change Over valve (reversing valve): Selectable for change over with heat or change over with cool
- Emergency Heat: In Heat pump mode, Emergency Heat mode is directly selectable from the thermostat
- Compressor short cycle protection delay
- Automatic heating and cooling changeover
- Fan Cycler feature
