IVB said:
I have 2 subnets as one of my switches is a managed switch (which is how I could tell the M1XEP was transmitting). I want the M1XEP on a different subnet than the servers as I separate video streaming traffic from low bandwidth/home automation stuff,
Technically you do not "have to" use separate subnets to isolate traffic. Yes, doing so will pretty much guarantee the traffic won't interfere. But if you've got decent fast switches arranged "like" subnets you can often get the same results.
The key is making sure the switches that are going to be handling the heaviest amounts of traffic are 'under subscribed'. That is, using a 24 port GigE switch but only using 12 ports on it. Assuming, of course, that the 24 port switch has a large enough capacity internally to handle all 24 ports. Using less than the max gives you some degree of 'room'. Then chain that into a likewise beefy central switch, with an uplink to your ISP router.
What you're looking to avoid is cross-uplink traffic. Keep as much as possible within a given switch and not traveling across the uplinks. That and you really do not want to set up too many levels of nested switches. I use a 'no more than three hops' rule of thumb. That was a requirement back in the days of passive hubs, but it's still not a bad practice to continue.
Where this can get gnarly is if there's multi-cast IP traffic being used. But if you've got that much going on then separate subnets is REALLY going to be a lot of trouble to configure. VLANs, likewise, can help but have their own set of headaches to consider.
Another factor to consider is IP address range size. Lots of folks default to using a class C range, which supports 253 devices. Going to a Class B changes that but there have been residential/low-end devices that are sometimes have issues with non Class C range configurations. As you start getting more devices you start running up against the limits of the ARP tables in the switches. This is another reason to under-subscribe switches. With a lot of devices you could eventually run into ARP table woes, but it's pretty unlikely in most residential situations. Subnet separation would help, but again raises complications with multi-cast and devices that just don't "play well" across subnets.
